Thread: Linkage Plate
  #34 (permalink)
Old 04-04-2012, 01:52 PM
jhirasak's Avatar
jhirasak jhirasak is offline
Cobra Make, Engine: 331 SB, AFR heads
To solve my problem of syncronization between the two banks of carbs, I recently purchased a center bellcrank with a needle pivot bearing from Inglese and mounted it on a machined 1/4 inch aluminum plate located between my carbs. Since my Webers are mounted in a mirror symmetric arrangement, they now stay within one unit of flow as measured by my Unisync from idle (1000 rpms) to 3000 rpms. For anyone who is using a single diagonal crosslink between the two banks of carbs arranged in a mirror symmetric configuration and having trouble with syncronization or transition response problems, I would highly recommend them to change to a center bellcrank arrangement.
