  #24 (permalink)
Old 04-05-2012, 03:09 AM
Default Good luck
wrench87 I am gald you finally got the correct answers. The best thing may be is to go back to a oem starter like Pat said if it will clear the area. The surface of the bellhousing should be flat and the mini would bolt up to it and still be 90 degrees to the flywheel teeth. Shelby blocks are different and the mini needed to have some grinding done to fix. Good Luck you are on the correct path. Rick L.
