Old 04-05-2012, 05:45 AM
strictlypersonl strictlypersonl is offline
Doug,
Check that you have 12V at the red wires of the connection to the voltage regulator. If you have power there, make sure that you have a good ground at the regulator and the firewall (below the starter solenoid).
Test the charging system with the procedure described in the Wiring Troubleshooting Guide.
