Old 04-06-2012, 10:43 AM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Originally Posted by Skuzzy View Post
If I recall, the Lambo uses a split journal crankshaft (18 degree?) which allows for even pulse firing while Dodge uses a 5 throw crank which is going to cause uneven pulse firing. Both use 90 degree blocks.
This makes the Lambo/Audi sound very nice while the Dodge sounds like it is on its last legs.
That is it exactly. If they had gone with either the split journal crank, or a 72 degree block, it would have sounded much better. Probably would have increased the redline by a few hundred RPM's also.
John Hall
