Old 04-08-2012, 09:24 AM
olddog olddog is offline
Pay attention to the part about manifold vacuum at idle. You want the vacuum advance hard against the stop at idle when using manifold vacuum. If you cam gives low vacuum at idle and you do not use the correct vacuum advance unit, you timing will hop around and that will make you idle rpm hop around with it.
