Old 04-08-2012, 05:49 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I think you have another problem to look at: motor mounts and tranny mounts. If you are braking the weld it sounds like you are getting excessive engine flex which it translating through the pipes. I'm guessing you tranny mount is shot or the steel x-member holding the mount is bending under load. I replaced my x-member with a thicker wall piece that reduced the bend/flex considerably.
