Old 04-09-2012, 04:56 AM
blykins blykins is offline
It depends on what the goals are....
For most of the cams that we run on street cars, with around .600-.620" lift, you'd never tell the difference between the 205 and 220/225 cc heads. In fact they flow similarly in the normal valve lift ranges. Also, when you can keep up flow without a lot of port volume, velocity increases....so in most cases the 205 head would be a best case scenario for a street car.
If you start adding higher lift cams and CNC porting, then it can become a different ballgame.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
