Old 04-09-2012, 09:12 AM
Bobcat Bobcat is offline
Dan ... without reading the whole three ... do you have the ERA IRS rear , and therefore , the large front rotors ? Mine has the Sierra calipers and the pads rattle with every bump . Per Sierra , they have .050" clearance all the way around as those calipers/pads are intended for competition and the clearance goes away when they really heat up . Don`t know if there is a cure as I don`t want to bind them up when I track the car .
I do have an issue with the steering universal joint ( I think ) where I get a slight popping sound with the car at rest as I turn the wheel back and forth .... Maybe some play as everything is tight and no bolts loose .
Bob
