Old 04-09-2012, 09:45 AM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Just a note on this Edelbrock 8843 water pump. If you have a CSR billet T-stat housing with the countersunk allen screws you'll need to remove this water pump to remove t-stat. WTF! just a heads up to any one else considering this pump that have a billet t-stat housing! also, FMS has a driver side input clockwise rotation alum. pump for $50 bucks vs edelbrock $180 pump...
OK...as I was just about ready to start pulling pump bolts...I did figure out a way to get the housing off w/o pump removal...here is the trick, take a 1/4 allen wrench, cut a 1/2 inch long piece off, install this into the allen bolt holding the t-stat housing on, then take a 1/4 inch box end on the allen wrench and it's off. what a *****! but it worked!
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
