Old 04-10-2012, 05:41 AM
joyridin''s Avatar
joyridin' joyridin' is offline
Well, what you may want to do is look for a rear axle from a 1994. Go to Northracecars.com and get different backing plates. This will allow you to use an axle from a earlier model in the car and you will have the disk set-up. If I recall, only the Cobras had disks in 1993 and they are different than 1994 versions. You can also buy the backing plates for the 11.65" brakes and upgrade. I narrowed the rear axle 2.5" on each side and bought custom axles. They are pretty cheap. This allowed me to remove all the spring perches from the frame and go with coilovers. You can then run a 315 size tire if you want to go with 17" rims.
I believe the rear mounting as mentioned above was a Streetbeast issue. Nobody seems to have ever mentioned it on the CMC's and mine was one of the last CMC's before they closed the doors.
