Old 04-12-2012, 09:31 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Here is what I found in my notes: Hope it helps:
With the transmission installed and bolted down flush to the engine, it is the time to check the position of the clutch fork. Take notice to where the clutch fork protrudes out through the opening in the bell housing. Push the clutch fork over towards the passenger side so that the throw-out bearing is just touching the spring plate fingers of clutch. The clutch fork should be either in the center of the square hole or preferably just towards the slave cylinder.
SPFWiringDiagrams@Comcast.net
