Old 04-13-2012, 02:11 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by wolf k View Post
Connected a vacuum gauge to the tap on the IDF carb, turns out that it is a ported tap. Had a nice steady needle, it was low at 7 in.hg at 1500 rpm, but only drawing from one cylinder. I do have a mild camshaft.
So although you only have 4 ported nipples, if you tee all the ported nipples together, you should get a higher average reading.
Gary
