Old 04-14-2012, 05:25 AM
patrickt patrickt is offline
Originally Posted by Cammer View Post
Could there possibly be some air in the lines that expands as it gets hot and moves the pedal up from the floor??
The only real trick to bleeding the ERA clutch is to make sure you have the nose of the car nice and high. What I do is put plastic surgical tubing on the bleed screw of the slave and have the tubing run in to a plastic bottle of DOT-3 or 4 fluid. I think that bleeder screw on the slave is like 3mm. When you crack it and start pumping you should have a really easy pedal push and a nice strong squirt in to the bottle. If you don't, then that tells you the problem is with the hydraulics and is not because of a clutch/pressure-plate/fork geometry issue.
