Old 04-15-2012, 11:04 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default quick fuel q 750
I purchased a quick fuel q 750 for my 445 fe, i was wondering if it will be ok out of the box for my first start up?. i will eventullay have it dynoed but wanted to know if i could do better then with the following
1) primary jet 74
2) sec jet 84
3) idle air bleed 73/73
4) hi speed bleed 33/33
5) pri nozzle 31
6) sec nozzle 31
7) needle and seat 110
8) power valve 4.5
my engine is for the street 10.0 comp ratio stage 1 keith craft edelbrock heads 2.09 and 1.6 valves, performer rpm intake port matched, comp cam hydraulic roller .598-.617 lift 230-238 duration at .050 112 lobe sep
msd 6al box msd dis 13 degrees initial timing 38 total timing
factory five mk III roadster, 445 fe stroker
