Old 04-20-2012, 07:43 AM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Default TR6060 trans questions.
Hi everyone.
So I have a TR6060 6spd man trans bought new for my cobra replica. It came with a oil cooler kit which I had to mount up.
Now as far as I know, these transmissions are rated 'filled-for-life', suggesting an oil change is never? required. So my question then, is when I install the oil cooler, would there be enough oil in the system to fill the cooler, or do I need to add more? And if I do, how do you check the oil level, and if required, add in some more oil?
Also, for a quick hydraulic clutch question, can the oil line between master and slave cylinders by 3/16", or does it need to be bigger? I see that the original HSV line is 1/4".
Thanks.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
