Originally Posted by vatdevil
Remove the speedo cable from the trans and count the teeth on the driven gear. Try the next tooth count available. Not sure what trans you have but a Tremec replacement driven gear is around $20. Just replaced mine due to tire size change, very easy to do.
Are these gears easily obtained at local automotive stores or will I have to order them online?
ETA:
To answer your question the trans is a Ford Toploader 4 Speed
I have a learning curve and I admit it.
