Old 04-23-2012, 09:59 AM
wicked fast's Avatar
wicked fast wicked fast is offline
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Thanks guys....
The stock unit was a remand Bosch unit that worked fine for 4 years. If you went to get gas you had to wait 10 minutes before it would turn over. It's just a huge heat sink. Timing is on the money, so I know that's not the issue.
I went to put a starter blanket on it this past Friday,seems the starter is just a hair away from the block. Don't think it would mount up with it installed.
So I asked here, checked a few sites, and ordered a CVR starter (thanks DougD). If it's good enough for George at Gessford to run on his engines, it should be outstanding for my little ole' 428.
Best,
BC
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
