Old 04-24-2012, 08:57 AM
madmaxx madmaxx is offline
higly unlikely your filter bypassed and if it did it is a clean oil bypass, meaning the oil does not bypass across the dirty filter media. As stated before it is differential pressure not oil pressure across the filter, at 212F and 12 gpm you probably had less than 2 psig differential across your filter where most bypass valves are set at 9-11psig. If you are using a ford racing hl-1hp bypass valve is set at 20 psig which I would not recommend.
