Old 04-24-2012, 07:51 PM
jhv48 jhv48 is offline
You can try greasing the cable. Sometimes an easy fix.
Simply unscrew the cable from the back of the speedo and the cable slips right out. Grease it and slide it back in.
If that doesn't work, then you might have to replace it.
If that doesn't work, you might have problems inside the speedo or the tranny gear. Most likely the cable.
Jim
