Old 04-25-2012, 12:37 PM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default 2" Gilmer belt
Originally Posted by RICK LAKE View Post
V-man Like Jerry been around racing a long time. If the motor is hot we ran between 1/4" and 1/2" of deflection. The problem is wear and tear on the bearings of the water pump and Alt. As long as the belt is not jumping teeth when hot I would leave it alone. Everything tightens when the pulleys, belt, and motor bay cools off. The belt is going to walk unless you have the pulleys all trued and at the same depth on the motor. We used to drill holes in the pulleys to help remove the air trapped with the motor running. This made the motor quieter and I think helped get a better deflection of the belt running. Rick L.
Your water pump speed is 1.3 x crankshaft speed. I found this out after looking on eBay at 1 x 1 crankshaft speed and a 1.5" belt.
There were no atheists in the foxholes.
