Old 04-26-2012, 09:40 AM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Dave,
Will be checking the liquid level in the pan so I can verify what/where 8 qts of oil is, and double check the dip stick.
In the past two or there changes I have drained the pan, and then added the new oil and noted the level for 6-7-8 on the dip stick...at that time start the engine and check it again, add as necessary
This time the notes go in my log book.
Using the water, pan off will be a good visual, and double check the stick, etc.
At this point the engine is coming out and getting cleaned out.
thanks, Pete
ERA 289 #2027
