Thread: Dyno failure!
Old 05-02-2012, 03:18 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
There looks to be an issue where the flange was weld onto the shaft I would say the shaft is a high carbon steel and the flange is a lower grade.... it looks to have broken where the two have been welded together. I think maybe a metalurgic problem between the steels and the weld and the heat...maybe a little misalignment aswell... The shaft and the flange should be spun out of one piece of Billet...
