Old 05-05-2012, 03:00 PM
pgermond's Avatar
pgermond pgermond is offline
What happens when you pull the cover and shift it into 3rd/4th gear? Does the shift fork move?
Yes, it appears that everything is moving and shifting as it should, but when I put resistance on the tail-shaft with the trans in 3rd or 4th gear and rotate the front spline the rear spline does not move... just as if it is neutral. 1st, 2nd, and rev work fine.
Phil
http://www.uniquecobra.com/
