Old 05-07-2012, 03:04 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I have a piece of 6mm Aluminium about 350mm square under the front. I have bolted the aluminium up to the bottom of the fibreglass and rounded the front corners so it matches the shape of the oil cowl. It runs from there back about 350mm and bolts to the chassis.... its tough and you have to put your head down under to see it.....
