Old 05-07-2012, 04:33 AM
CMY-427's Avatar
CMY-427 CMY-427 is offline
Cobra Make, Engine: 1995 Snake Pit DRB "Coca Cola" , 5.0 LT HO , T5
Originally Posted by AC-460 View Post
I have a piece of 6mm Aluminium about 350mm square under the front. I have bolted the aluminium up to the bottom of the fibreglass and rounded the front corners so it matches the shape of the oil cowl. It runs from there back about 350mm and bolts to the chassis.... its tough and you have to put your head down under to see it.....
I did the exact same thing except that I ended up making two, both bend up at the front at the same angle as the cowl however the 1st is only bent up about 15mm which does not block the cowl off, however the 2nd one does extend up further than this as it also acts as the number plate mounting bracket. I have painted the aluminium so it blends in a little better and luckily have not scraped the bottom of either as yet
