Old 05-07-2012, 06:37 AM
elmariachi elmariachi is offline
Originally Posted by donnieR32 View Post
Yeah, I was really surprised when he said he was going to mix oils. I found that odd. Anyways, for me cam is Crower flat tappet.
You can either run a ZDDP additive to conventional oil or even better, just run an oil like Valvoline VR-1 Racing or Brad Penn that still has the higher levels of zinc. But do one or the other before running the engine.
Search "zinc" here as this has been discussed ad nauseum.
And by the way, to the comment above about zinc not adding much to an engine already broken in, this is NOT the case with a flat tappet. You really need to run an oil with elevated levels of zinc for the flat tappet and solid lifters.
