Old 05-07-2012, 07:54 AM
wolf k's Avatar
wolf k wolf k is offline
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Default Any advice with my tuning
44 IDF's on 331 small block with mild cam, 212 duration, 112 lobe separation. 20 deg initial timing, 140 mains, 175 airs, 55 idles, 65 pump bypass, F11 tubes. 12.6-13.6 air-fuel ratio through all ranges of operation. Runs great, plugs look great.
My issue is, while moderately accelerating in 1st gear from a stop, I get some minor stumbling and fluttering from the exhaust in the transition zone, 2800-3000 rpm. If I accelerate slowly, no problem. If I accelerate hard, no problem again.
My AFR meter is not indicating if this is a lean or rich stumble, it stays in the 11-13 range through idle to full throttle.
The Pierce Manifold tuning guide states as follows; the emulsion tube influence is more marked at small and average throttle opening angles and during accelerations. This sounds like where my problem may be.
I already have gone through many jets and different combinations to get where I am now. It looks like I need to start guessing at emulsion tubes. At $12 a tube x 8, I would like to start guessing in the right direction. Any advice on which one?
