Old 05-07-2012, 10:46 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
From what I've read, having high zinc is only half the solution. Modern oils have higher detergent levels. These detergents "clean" the zinc off metal surfaces. Accordingly, a zinc additive is ineffective. Oils like Joe Gibbs have lower detergent levels as well as higher zinc content.
So, if your engine will benefit from higher zinc levels, it is probably wise to use an oil formulated with it instead of trying to add it yourself.
Regards,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
