Old 05-08-2012, 05:30 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Shaft and Pushrod oiling system with T&D Rockers??
The newer T&D rockers for use with Edelbrock heads, these are the ones that do not require the heads to be machined, are set up for both shaft oiling and oiling through the pushrods. (lifters->pushrods->adjustment nut-> and finally rocker body) Is it ok to run both types of oiling systems at the same time?
