Old 05-09-2012, 06:58 PM
olddog olddog is offline
Depending on the Hp of the 347, 24 lb/hr injectors may not be big enough.
If you change the engine displacement or the injectors the computer need to be updated with the correct information.
You need to know what ECU you have for starters and if it uses a mass flow sensor or Manifold Absolute Pressure (MAP).
