Old 05-10-2012, 06:36 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default need cam bolt for tbird /Mark VIII setup
Hello All,
I know your setup does not use the Cam bolt that is found on the 1997 T-Bird rear suspension or 1998 Mark VIII. Please dont throw this away . I am looking for 4 of these bolts. This will help me with my project.
Basically, this is a bolt that is 5 inch long x.60 with a eccentric washer on either end to adjust the camber. There is usually 3 per side.
Here is a picture:
http://image.shutterstock.com/displa...s-72981883.jpg
Please help if you can. This is no longer found at the dealer or aftermarket.
The replacement units dont look as strongs as the factory pieces
Thanks
