Old 05-12-2012, 05:11 PM
blykins blykins is offline
You shouldn't have to remove the gear. The roll pin you want to drive out is in the aluminum sleeve up above the gear. If you drive the top roll pin out, then slide that sleeve down, then you can slide the shaft up far enough to put the pin in the advance stop hole, rotate it 180°, then push the shaft back down so that the pin goes in the hole in the distributor.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
