Old 05-14-2012, 08:01 AM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Ummm, the bulb shot off yesterday when i was heating it up to see if the gauge worked. Luckily, i had just pointed it away from body.
UPDATE: For some reason the temp gauge is working without the probe attached. There is a pocket of air where the wire sits inside the threaded fitting in the intake and i suppose that the air pocket is being filled with gases from the hot antifreeze and that is making the gauge work. I checked the reading on the engine with my infrared gun and compared it to the gauge and it's accurate. Go figure. I dont know if i will trust it, but its working
