Old 05-14-2012, 10:34 PM
budski budski is offline
Originally Posted by joyridin' View Post
I assume you haven't torn anything apart yet, but are you sure the issue is too much pressure to the fronts? Maybe it is not enough to the rear...like one or both of the rear calipers is seized?
it was already torn apart and I'm missing one spindle and one caliper, really sucks because I was hoping to trouble shoot the issue, unable to bleed the system all I can tell is that it may have the MG master cylinder that could of been used from a disc/drum setup causing it to sent more pressure to the fronts
Originally Posted by Ron61 View Post
Just a thought but does it have adjustable brake bias or is it a fixed bias unit? That may be something that you would want to check while you are this far into it.
that will be added, but not for a "fix".
