Old 05-15-2012, 10:20 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by mike p. View Post
Thanks for the suggestions so far.
Are you talking about the 2 part epoxy that mix's together?
The crack under the hood is only on the bottom part of the hood. So far its just starting to crack the paint (all on the bottom, nothing showing on the top).
The crack is not wide enough to spead yet. Is this something that happens or just a one time problem?
Thanks again, Mike
They make regular fiberglass bonding agents to adhere fiberglass panels but for something small like the edge of the hood, I would just use a little JB Weld or similar 2-part epoxy.
I have an old Corvette and making repairs of loose bond joints and stress cracks is a routine part of all re-painting efforts. No way to tell if you will have further instances. Most Cobra bodies are fairly high quality and durable. If you end up repairing this area with epoxy, I'm pretty sure it will not repeat in the same place.
You still might post a picture of the underside of the hood. Sight unseen - I kind of wonder if it might be a small area of body filler that is coming loose. If it is, then that will eventually have to result in some body and paint work - but it probably won't show on the top side.
