  #26 (permalink)
Old 05-19-2012, 01:53 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Roger Bray View Post
I don't have an MSD. Just the dist that came with the crate engine from ford.
The car has been sitting all night so the engine is cold.
I took a video of the choke before I tried to start the car.
https://www.youtube.com/watch?v=mRjnq8tt9zw
It fired right up but only ran for a few seconds because I forgot to turn the fuel pump on.
I tried starting it again with the fuel pump on without success.
Here is a video of the choke right after the start attempt.
https://www.youtube.com/watch?v=U0FVoL_fUi4
Maybe I need a new electric choke.
It is in the full open position. It has 12v going to it. The negative terminal on the choke is hot to the touch. Is this normal? Also I tried adjusting the choke by rotating it but nothing happened.
There's something wrong with the choke fast idle cam not allowing the choke to close.
If the negative terminal is hot, you have a bad ground.
Gary
