Old 05-22-2012, 04:18 AM
Default Great clutch
Rosco. I have one install behind my 482. Still breaking in. Only 540HP and 620ft of torque.
Couple of questions, why not go to a TKO 600 or Richmond super street 5 spd with over drive?
Follow the instruction to the letter, Blue locktite on all fasteners. Toque to specs.
When installed make sure you have complete disengagement on the jacks looking of .035" clearance with clutch pedal in.
Breakin as told with about 500 miles before any WOT runs. It gets better with heat cycles.
Clutch pedal stop under dash. You might have to do this to stop from over extending the slave cylinder or bending the forks. This also applys to HTOB too.
Good luck, wait till you use the pedal a couple of times, can't believe how easy it is. Rick L.
