Old 05-22-2012, 07:44 AM
blykins blykins is offline
Rosco,
I've tried to return your phone call several times. Each time I get a messages that says the number is no longer in service? Weird.....
Pete,
The aluminum FE flywheels that I use are 14 lbs. The steel ones are 28-30 lbs. Factory style steel/cast iron are closer to 40 lbs.
The RST clutch is very light as the adapter plate is aluminum and the pressure plate is 9.5".
I used both steel and aluminum flywheels on my own Cobra and I didn't like the aluminum flywheel at all in a street driving style setting. That was with a 428 FE, a TKO, and a 3.70 gear.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
