Old 05-23-2012, 08:01 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Assuming there is only one hose connection on the diaphragm assembly:
If you are sure you are applying vacuum and it holds the vacuum, it should have moved the distributor trigger plate.
The logical assumption is that the diaphragm pot is seized.
If it doesn't hold the vacuum, the diaphragm is ruptured.
In either case, it needs to be replaced.
Jim
A Gnat! Quick, get a sledgehammer!
