Old 05-24-2012, 09:35 AM
FFR6870 FFR6870 is offline
Cobra Make, Engine: MK 3.1 FFR-6870, 521 cid
Thank you Jason, I greatly appreciate your answer. The block and rotating assembly is going to be gone through by a machine shop, I will take the website you referenced and ask to have the modifications made.
I have heard others say that running an oil cooler could actually contribute to the starvation issue, but I see you are using the -12 AN lines. Do you track the car? If so, with your setup, is the problem "fixed"?
Thank you again for your response.
