Old 05-25-2012, 08:51 AM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
Brad,
Here is a story for you. The first owner of my car (SPF 239) had a Canton road race pan. While racing the car (on a banked track) it oil starved and killed a rod, piston and cylinder liner (alum block) When the motor was rebuilt, he went with the Aviaid pan and the Accusump. That was in 1999/2000, 12 yrs later the motor still has 65 psi at idle. The other benefit of the Accusump is its ability to pre-oil the motor during startup. turn the key to the ACC position and wait for the oil pressure to come up, then start it, never turns over dry.
I would go with the Aviaid and Accusump, you will be money ahead in the long run
Jason
