Old 05-28-2012, 08:52 AM
Stentor's Avatar
Stentor Stentor is offline
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Originally Posted by Cobra Braggin' View Post
Thanks for you comments. I've heard a lot about the heat from BB 427's. I've often wondered in you can special order extra insulation between you and the cockpit firewall when you speak with SPF to cut down on the heat in the cockpit?
Cobra Braggin'
"Cobra Man For Life!"
Olthoff can add extra insulation--during the install--to help mitigate cockpit heat.
With a name like "Cobra Braggin," one could posit that you'd be inclined to go with an FE big block.
