Old 05-29-2012, 02:04 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Tommy View Post
The Crane instructions say much the same thing, but also mention the use of spacers if 1/4 to 1 turn of tightening does not produce the specified torque (lifter compression). My concern is that the nut is at the specified torque, but the rocker is loose enough to allow the push rod to spin freely. I assume that means I need to play with the spacer to get the preloads correct. Does that sound right?
By the sound of it, you have non-adjustable rocker gear.
If the point of zero lash is less than 1/4 turn from the tightened point of the fastener, then the spacer is too thick.
Then you have do some maths.
Gary
