Thread: FE Oil Purge
Old 05-29-2012, 08:34 AM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
I am 99% sure the leak is not from the intake manifold as I redid that twice last year and I looked in all the usual areas prone to leakage and I don't see anything. The flow seems to be coming down the back of the block but in front of the bellhousing which leads me to believe it is not my rear seal. What is really confusing is why the leak only occurs when I turn the engine off. As soon as I cut the power, a stream of oil pours out and then it stops. The car is not leaking oil while it is running. Very confusing.
