I doubt your low compression on cylinder 8 is to do with no preload on your hydraulic lifters.
I would take all of rocker gear off, to check that all of the valve stems are at the same height.
No preload (now a lash clearance, the opposite of what it should have) and low compression points to bent valves.
Gary
