Thread: 373 v 411's ?
Old 05-30-2012, 05:12 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
3.73 is about as low as i would go. the engine is pretty strong with the svo block. it probably has a vic jr intake, you can replace that with a rpm air gap and that will give it some zip. the cam is probably retarded, advance about 4 degrees and that will help. change heads will help little. i did a write up on doing this if you search. getting rid of the heavy 40 pound flywheel/clutch for a lighter unit will help quite a bit.
