Thread: FE Oil Purge
Old 06-02-2012, 03:25 AM
Default Before going crazy lets--
Mongoose930 Jim been reading my threads. Elmaraichi has it right. Go and buy the leak finder kit with the dyes. Make sure you oil is full and run the car for a couple of minutes. use glasses and light to find leak and repair. This is right out of the manual. I don't understand why you have no leak with motor running and get a flood with motor off. You have good oil pressure with motor running?? If your car does have a PCV in it, there may be enough vacuum inside to keep the oil from leaking out and when motor is turned off, out comes the extra. I am thinking valve cover gasket leaking between intake manifold and head. Returns are slow. Do you have the tins under the rockers?? Get kit and you will fine out. Rick L. Ps Jim you have learned well, grasshopper.
