Thread: FE Oil Purge
Old 06-02-2012, 11:02 AM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
I torqued everything down this morning and let her warm up for a while. As usual, no leaks while the car was running. As soon as shut it down, I saw the oil leaking from the crack between the intake manifold and the head at the back of the block on the drivers side. I put so much time and care into replacing the intake manifold gasket this past summer that I can't believe it is leaking again!!! I guess the good news is that it isn't anything major. I am going to buy a syringe and try to fill the crack from the outside. It probably won't work but I figure it is worth a try.
