Old 06-03-2012, 12:02 PM
Racer_X Racer_X is offline
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
Depends on what type of shifter you have, at the bottom of the shifter handle are usually travel limit stops. They are bolts with lock nuts. You have to loosen the lock nuts then back the bolts out a turn or two. Then tighten the lock nuts down again. These control the travel throw of the shifter so as not to bend the internal shift forks or tear up the transmission internals.
