Old 06-03-2012, 03:32 PM
patrickt patrickt is offline
Originally Posted by elmariachi View Post
I also disconnected the pushers for now and that seemed to help slow the escalation, probably because they were disrupting air flow.
This is the only part of your post I can comment on. I have the big 16" SPAL puller with straight blades and the dual pushers. I have them wired separately and have experimented with them quite a bit. They absolutely work in concert to increase the cooling effect. I do not use the pushers all that much, but when I put them on while the puller is also running, at idle on really hot days, they're good for dropping the temp an additional five degrees or so.
